How do I remove instrument cluster, pls?
I need to replace my ignition switch and understand I need to remove the cluster to do it. This is a 1994 100S automatic. How do I get the cluster out, pls?
Just remember to place a towel over your plastic steering wheel console cover to prevent scratching it by the IC.<ul><li><a href="https://forums.audiworld.com/a6100/msgs/47727.phtml">IC Removal Guide</a></li></ul>
Thank you! I searched this site several times using 'instrument cluster', 'cluster removal', etc and never found that!!!!!!!!!! Didin't occur to me to search on 'IC'!
David W.
David W.
I'm not surprised you didn't find anything. You should find several posts about instrument lamp replacement. The Audiworld search function has been broken for a long time. I just searched for "instrument panel lamps", the exact words in the posted procedure and came up with "0" hits.
Recently, searching for even the most common things seems to yield little or no results. Now that I think about it, it seems it has been doing this for a while... Oh well...
~scrogers
~scrogers
Go to an external seach engine, e.g. http://search.msn.com and type:
site:forums.audiworld.com <search words>
e.g.
site:forums.audiworld.com cluster removal a6
HTH,
Manu
e.g.
HTH,
Manu
Great! Thanks. If I add "a6100", I get just this forum. Excellent.
example:
site:forums.audiworld.com a6100 cluster removal a6
example:
SILVER1
05-09-2015 01:29 PM
Ed@mtl
11-05-2005 09:43 AM
NeverEnough
10-15-2003 06:46 PM
Stang Guy
12-18-2000 06:22 PM
