How hard is it to remove the power seats?
I need to replace the seat switches (up, down, back, forth, etc.) but there are also some loose things under the seats so I would like to take them out to have a look. I think I may be able to replace the seat switches without taking the seats out?
Yesm you can remove just the switch...(more)
I think there are two or so screws behind the trim that the switch pack is attached to. If you look under you should be able to see the screw you need to take out. Then the whole pack just unplugs, and plug your new one in. Only hard part if you would call it that is to get to the screws, but its very do able. Just make sure you have some short screw drivers, took me a little looking in the garage to find a size I could use for one of te screw. Good luck!!!
Ugly Joe
12-18-2002 12:39 PM
