I can't seem to find the A/C low side service port for my 95 A6 quattro!!!
Old 08-30-2004, 08:18 AM
New Member
D10Lax's Avatar
Default I can't seem to find the A/C low side service port for my 95 A6 quattro!!!
I need to recharge my refrigerant in my car but i can't seem to find the port does someone know where it is on this car?
Old 08-30-2004, 08:36 AM
New Member
Rokokko's Avatar
Default Re: I can't seem to find the A/C low side service port for my 95 A6 quattro!!!
It is sitting on the kompressor
Regards from denmark
Old 08-30-2004, 10:01 AM
Tech Guru
4Driver4's Avatar
Default There is no low side service port.
The AC is evacuated and charged through the high side port - not a DIY job.
Old 08-30-2004, 10:08 AM
New Member
Ken Clunk's Avatar
Default No low port...
There is no low port but there is a low "switch" under the top left of the hood. I myself have almost no pressure in the system and am thinking of installing a low pressure port in the tubing up there. I have not had the time to check it out but think that it will work.
Around me they were going to charge and hr of labor ($79) plus the cost of the fluid, being that I have a small leak I decided not to waste my money.
On a side question, does anyone now if the auto climate control nows the exact temperature of the cold air and the hot or does it just assume that they are at the correct temperatures and adjusts accordingly?
Old 08-30-2004, 02:34 PM
New Member
Rud67's Avatar
You can add to the high side when the vehicle is off. When the compressor is NOT running and the vehicle is off there is NO high or low side. ITS ONE SIDE.
Rudy<ul><li><a href="https://forums.audiworld.com/a6100/msgs/40144.phtml">https://forums.audiworld.com/a6100/msgs/40144.phtml</a</li></ul>
Old 08-30-2004, 07:03 PM
New Member
gobroke's Avatar
There is a service port, Its under the hood on the passenger side near the windshield. There is a black plastic cover over it, if you follow the the refrigerant lines up toward the windshield you'll see it. There is a low pressure switch attached to it (a clip with 2 wires on it). If your gonna convert it over to 134a make sure its completly empty of R12 first. Please dont try and charge it from the high side.
Old 08-31-2004, 04:50 AM
Tech Guru
4Driver4's Avatar
1995 is 134a. No conversion required. Should be charged through the high side only per Audi.
Old 08-31-2004, 04:46 PM
New Member
Rud67's Avatar
Exactly DO NOT Charge it from the high side.
USE THE HIGH SIDE PORT TO ADD FREON, WITH THE ENGINE OFF.
Dunno why everyone is so scared to add freon to the high side port. WHEN THE ENGINE IS OFF, BOTH HIGH AND LOW SIDE ARE THE SAME...I have done it many of cars with great results
Old 06-28-2024, 09:52 PM
egp320i's Avatar
You can't even if you wanted to as any can of 134 you buy only has a fitting for the low port
audicabrio97
09-27-2009 11:33 AM
ThetaTau87
08-02-2006 10:04 AM
zukboy
Audi 100 / A6 (C4 Platform)
07-04-2005 06:37 AM
Zsolt
07-16-2003 11:52 AM
Scott Long
07-11-2002 10:17 PM
Quick Reply: I can't seem to find the A/C low side service port for my 95 A6 quattro!!!
