Is a leaking rear main seal a common problem on a 94 100? Any idea how much to replace on
a 5 spd non-quattro?
Also, does the rear main seal leak oil or lube?
Thanks
Thanks
may seep a bit above. The leak comes from the back of the engine, mostly driver's side but leaks on pass cat.
I can't see the head gasket on the firewall side, so it may be leaking there.
UrSoccer_mobileĀ®
11-27-2002 11:49 PM
ccagle8
07-10-2002 12:12 AM
