Massive coolant leak...
I went out to check on the oil, everything good, but I notice the coolant resevoir is nearly empty. It was full not even a week ago. Not good.
<img src="http://pictureposter.audiworld.com/37457/im000033.jpg">
Everything looks dry, clean, no o-ring leaks... Oil dipstick looks fine, no foam on the oil cap either.
<img src="http://pictureposter.audiworld.com/37457/im000030.jpg">
Under the car I notice this:
<img src="http://pictureposter.audiworld.com/37457/im000025.jpg">
<img src="http://pictureposter.audiworld.com/37457/im000027.jpg">
<img src="http://pictureposter.audiworld.com/37457/im000028.jpg">
I'm thinking something is leaking from this location. One of the clamps or the bleeder. Any ideas?
<img src="http://pictureposter.audiworld.com/37457/im000032.jpg">
I can't tell if that coolant is dried up or what. It might be from when someone was burping the system through that blead screw. Either way, now that I think about it, i'm not sure the coolant would exit under the car there if it was leaking that bad. Maybe it's coming from another place behind the engine. We need more pics...
and none of the hoses are leaking then it looks like you will be performing an R&R on the heatercore soon;-(
<center><img src="http://www.mnsi.net/~natwhite/C4%20bleeder.jpg"></center><p>a leaky bleeder valve screw. Easy fix, but expensive! $65 for a small rubber hose.
Part # 4A1 819 373 F
