More on "Won't Start" ...ignition switch???
96 A6 Avant Q - So, while I'm waiting for my VAG-COM kit to arrive, I'm doing some reading. CVTech said it could be the ignition switch. I still have the original switch in the car. It has been giving my wife problems for quite a while now. The car would always start but just wouldn't return back to the "Run" position. My wife knew that if the climate control etc. didn't work she would just crank the key back a little bit to the run position. So now, one morning it's dead. I read the ignition switch FAQ here: https://forums.audiworld.com/a6100/msgs/51822.phtml and it says non-starting could be ignition switch. Will the VAG-COM tell me whether it's the switch?? Should I just go ahead and replace the switch anyway and diagnose from there?
Dunno if VAG will diagnose a faulty ignition switch or not. I'd say no though.
Rather than wait around for the VAG, I'd replace the ignition switch. Takes 30 minutes or less, is something that from the sound of it has to be done anyway, and will in all probability solve your problem.
i dunno if thats post or pre in column ignition switch or not but my boss has complained about having to remove bad switches from in dash more like 20 min with an air saw to get to the thing!
def diagnose the car first!
I cant really remember what the switch is like on that model and shouldn't have posted. but i would run a test with an obd checker.
boxster02
08-15-2006 11:15 AM
