Need some help, why does my Automatic trans make a rattling sound only during cold start? Goes away
Re: Need some help, why does my Automatic trans make a rattling sound only during cold start? Goes
It could be that you are getting some cavitation because fluid has drained out of the feed tube to the front pump. Have you changed a auto trans filter lately?
Yes, changed fluid & filter. Followed instructions and amount out matched amount in.
If the feed tube to the front pump was air bound, would the noise disappear after a short while?
MikTip, it doesn't sound like the cats normally do. I went under the car and it sounds like it's
coming from the trans pan. I replaced both my cats in the past couple years.
Re: Yes, changed fluid & filter. Followed instructions and amount out matched amount in.
Did you use the "audi part" from the dealer or an after market one? very important. some aftermarket filters have a little smaller opening for the filter into the pump body. without a tight seal, air gets into the flow.
I didn't purchase one directly from the dealer but did order it online from a reliable source.
I don't recall the packaging all that well but it was in a plastic bag with an Audi type number on it. I also replaced the oring. I will give this a shot on Monday. I though the fluid may be low or the filter had loosened sucking air in between so I took it apart a couple days later to check. The bolts were still fastened to the correct torque.
Thanks to the info.
Thanks to the info.
