Oil change / service reminder re-set
1997 A6Q has automatic oil change / service reminder indicator flashing on the trip odometer. Any way to re-set this without dealer intervention? I've heard of later models being able to be re-set.
Thanks in advance.
Thanks in advance.
Audi A4 & A6 (All years)
* Turn off the ignition
* Press and hold the button on the left side of the display while turning the ignition on
Service OIL will be displayed
* Pull out the button on the right side of the display until the service prompt is cleared. The display should now read ---
If the above procedure does not work, outlined below is an alternative procedure:
* With the ignition off, push the right button
* Turn the ignition on and then pull the left button
* This should clear the warning message
Hope this helps
Hope this helps
romansoldier
09-25-2003 11:26 AM
