Oil pump & oil pan gasket replacement with part numbers and other tid bits of info
Thought I'd make a seperate post just to give some brief details and offer up some part numbers.
As some of you have read, I had a leak from the top of the oil pump and had to replace the gasket. During tear down, I missed a 6mm bolt that went from the upper oil pan into the bottom of the oil pump and broke the upper pan. I had the pan TIG welded and surfaced, so that turned out okay.
When it came time to buy gaskets, there was a problem figuring out which gaskets my AFC engine took and I wound up getting the wrong gaskets for all 3 locations....lower pan, upper pan, and oil pump-to-block.
My car was built in 4/95 and the last 6 of the VIN are: 099292.
The correct pump gasket is Dealer only: 078-115-189F (That "F" makes all the difference! The "D" version will not work)
The correct upper pan gasket is: 078-103-609E
The correct lower pan gasket is: 078-103-609G
The correct front crank seal is: 034-115-147A
The correct water pump is: 078-121-004J
I actually drove to Royal Audi in San Francisco yesterday in order to buy the correct oil pump gasket, so I could finish the car today. Nice 430mi/7+hr drive for a $13 gasket.
shipped to you (tell him your an Audi Club NA member for a 15% discount). Or you could have had the a SF Bay Area dealer ship it to you via Greyhound Bus for same or next day delivery (or even FedEx). It would have certainly been cheaper than making a 350 - 400 mile roundtrip.
But then thought...watch some guy in the parts department drop the ball (as they always seem to do) and then the gasket is a no-show.
So, it was worth it to spend $40 in diesel and take a road trip in my Rabbit Pickup. Would have probably been $10-$15 to have it FedEx'd.
Plus, it sure feels good to have the car back together!
Bebeto
12v V6 Discussion
01-03-2009 09:39 AM
Bebeto
Audi 100 / A6 (C4 Platform)
14
12-29-2008 10:18 PM
austinado16
12v V6 Discussion
08-06-2006 08:27 PM
