OP needed on floor jack
What have people bought and tossed aside? I'm considering getting either a Michelin 3 1/2ton or Sears 4ton. My current jack can't get high enough for me to use my 6ton stands. I won't get under the car until I can use these stands (they look like HF). Does anyone use a crossbeam adapter?
6 ton stands are pretty tall, you will probably need a block with any jack unless you get one of those enormous bus jacks.
The "rhino ramps" I have are only 5" or 6" high. That's (barely) enough to crawl under and do an oil change on the S4 (much lower than the A6) but not much more.
Just wondered about jacks and cross beam extenders. I use the ramps for the quick and dirty jobs but they don't work when needing the wheels off. I also can't remember what the ramps are rated at as they are the old metal ones. I guess it calls for a trip to Sears.
