Is it possible that a leaky a/c compressor could just be the o-ring?
AudiWorld Expert
or gasket for the compressor that's hardened and is leaking? I've learned that most a/c compressors have gaskets/o-rings that will go bad. Since the compressor is still spinning and working, does this seem like a possible problem for a leak?
Most of the compressor seals are servicable but no one wants to do it. Usually its the input shaft seal behind the clutch. You need a puller to get the clutch off as well as a new seal. Good luck finding it. You also need to know the air gap setting for the clutch and the adjustment requires shims, good luck finding them too!
escargot
13
05-31-2002 09:14 PM
