Radio Problem!!! Need help
Hi, finally I got my radio code..but somehow my radio is not working properly...Only ONE speaker sound/work (back rear driver side). I don't have the radio manual to look up..I check all the speaker fuses and wires..they seem to be fine...driver's speaker also make sound when I open the door (it's a EEEEEEEEEEE sound). Where can I find the balance controller for radio? how do you get to the radio system to make some changes? any idea why only one speaker play and the others are not? I also have the 10cd changer..it's not working either..no power and whatsoever...thanks
Re: Radio Problem!!! Need help
Hi,
Sounds like the amp is shot. This is not uncommon according to these guys. Read on!<ul><li><a href="http://www.carstereohelp.com/straudi.htm">http://www.carstereohelp.com/straudi.htm</a</li></ul>
darn!!! so the main amp. is located on the driver door? it's kinda weird that one speaker still play on the back..and when I open the driver door...front driver speaker still make a warning sound..but not like normal sound...thanks
There are actually 4 amps.........
1 per speaker. The two front speakers are individualy amped, they have amps built into the speaker enclosure. The back 2 speakers are also controled by 2 amps, but they are enclosed in a case under the back lid in the trunk. It's 1 enclosure, but houses 2 amps.
The guys that torquenut mentions are great, I had them repair my rear amps, little pricey, but sounds great and there warantied for life.
good luck.
good luck.
Repair was a bit expensive.....
but i wanted to be sure it would work, and the repair is warrantied for life. For the rear amps it was $180 (2 amps, $90 a piece). You could proabably find a used one for under a $100. good luck.
actually..I am searching for a use one..don't like to pack and ship situation..and ofcourse $$$.
Yes..I like to the factory stereo..they sound very great...thank for infor DJ
WeHoGuy
Q5/SQ5 MKII Discussion
03-13-2018 03:06 PM
drixtab
04-16-2013 06:30 PM
