rear brake calipers .....
so I had my back brakes (95 A6 Quat) apart today and aside from not having a big enough C clamp the only real question I have (well there are two) number one the piston in the caliper does it go in and out or does it turn (I have to get this back in order for the new pads to fit on properly, right?)and second is there anything I ought to know that I am missing ? It seemed way to easy to pull them apart and out them back together!!!!! Thx in advance all-J
There is a special VAG tool that is used for teh rear calipers. But in a pinch, you can use a pair of large pliers to grip and rotate the piston, and then push inward. If you use pliers, just be carefull that you don't pinch the boot or scratch the piston surface.
figures there is a special tool .... lol. Thanks guys so clock wise and push at the same time... kinda glad I didnt have a big enough C clamp cause I would have wrenched down on that bastard and ruined the thread !!
open the bleeder screw with a small hose on it and force the brake fluid out the bleeder instead of back through the brake lines. Pushing old fluid with potentially rust and other junk in it back through the ABS pump can damage or shorten it's life. And them bastards aren't cheap/fun.
that allows you to spin the piston while applying pressure. The one got has 4 sides for use with different calipers...it required a little modification via grinder but works nicely for $5.
<center><img src="http://www.harborfreight.com/cpi/photos/40700-40799/40732.gif"></center><p>My pistons must have been welded in place when I tried that crappy cube...
holding the caliper and a wrench and trying to keep the cube in place SUCKS..
I picked up the caliper tool set from harbor freight.. best $30 you'll spend this week
It was actually REALLY easy. Just hooked up the ratchet and a 3-way C-clamp (E-clamp?) applying downward pressure. Alternated twisting one then the other. Only force needed was for spinning each. No blood drawn ;]
I'm sure the proper tool is easier to use, but if you're in a squeeze those work fine.
