Reverse Lights, search wasnt much help, plus...
94 100CS Avant. Dash Registers reverse, reverse and mirror tilt work at their own will, how would i go about repllacing the reverse switch (any pictures would be good) The car is having the front left drive axle and right front tie rod replaced soon, was hoping to get this fixed also. Side note does anyone want to get rid of OEM fog lights for this, both mine were shattered over the winter, I'm sure I'll have more questions soon.... I'M NEWISH!
Edit: I think the switch I need is number 31? Anyone?
<img src="http://img131.imageshack.us/img131/1984/untitled15as.jpg">
so is this the correct switch? I tried searching for reverse switch in my ETKA but no dice, also is the front axle called the drive shaft? I'm a moron.
switch does communicate with the selector lever indicator on the dash. If you're getting incorrect position indications, then the TR switch is probably defective (per Bentley §P37-32). You'll need to remove the left transmission mount in order to R&R and adjust the TR switch.
SpeedyDTP247 CQ+UrS4
12-18-2007 12:40 PM
PanTTher
11
07-27-2004 02:32 PM
My plan: Hook up my E-Code city lights to a switch like the fog switch where the ESD switch would go
A4Anth
08-11-2001 05:55 PM
