Squeaky A6
My '96 A6 Wagon's suspension squeaks like a cheap motel room bed, especially in the rear. (there's a joke in there somewhere). Is there any way that I can use some kind of silicone based spray or anything else to lube whatever is making all the noise? Is it the bushings?
There are links in the rear suspension, names of which I forget. Basically, if you manage to have your car up, try moving rear wheels from side to side. Grab it at the lowest point and just move it left and right (and a little bit up and down). The links that are worn out are in the upper suspension.
I tried spraying WD40, and it worked for only 1 day, 2 days at most.
twopedalwarrior
07-06-2017 04:03 AM
TheObjectivist
24
07-16-2011 09:42 AM
JEMiller
08-30-2007 12:21 PM
