Stereo Speakers Sound...need help
Hello...my speakers are not working (no sound) two from the front and one from the rear..I replace the rear (work great) but the twon in the front still have no Sound. I test the front's speakers (both still work as normal) but still no sound when I hooked them up..any idea why its doest that? also it make a EERRRRSSS sound when I open the driver side door..and my Antena won't go down when I turn the Radio off either...but when I unhook the front driver side speakers..the antena go down when I turn the speakers and the EEERRRRSS sound also gone too..I am trying to figure out why the two front speakers don't make sound? anyone got this problem with your stereo? how to fix this problem? many thanks...
I have the same problem with my 92 100CS. The speakers were replaced, and it still does not work. However with the back speakers working it doesn't sound bad.
work fine when connected to different wires...I am having hardtime to figure out which wire/fuse shorted...b/c it make eerrrs sound warning everytimes I opened the driver door...thank V-B..let me play with it a little more to see what happen...
-AbsoluteaudiCS-hey..will let you know if I discover the problem..is your antenna go down when the power was off? and do you have the eerrs warning sound when the front driver door open? thanks
well...I don't think the front amps are shot..I replace my front speakers with a new one..but it still don't make sound either..but when hook up to the back speakers..it sound find..so something wrong with the wire/fuse somewhere!!!
my front speakers dont work on my 100cs and ive been told its cuz of the amp. What can i do??? by the way i have the complete bose system, so its hard replacing just one part
It makes a loud blurr noise once and a while. The doors are closed and if I turn the radio on and off it fixes it.
Let me know what you find out
my rear speakers got built in amp on the back of speakers..I just replaced the back..it working good now..but still work on the front speakers..will update when solution found!!!
bril814
A4 (B8 Platform) Discussion
08-14-2017 12:10 AM
OMP
03-18-2013 06:23 AM
Mums
06-09-2009 06:55 AM
