Strange Downshift Problem
I have a '98 A6 wagon, 111,000 miles and very well maintained that generally shifts just fine. The only problem is when I am driving up a canyon, or up a long grade. The car upshifts just fine (either to 3rd or 2nd, depending on my speed), but when the road levels back out the car does not immediately shift back into 4th (or 3rd as the case may be). It may be as long as 10 to 15 seconds before it downshifts. This only happens on longer hills. I just fully serviced the transmision, but the problem seems to be the same. Any suggestions? Thanks in advance.
Also, make sure you drain and fill your transmission fluid and change your filter.
AndreSilva
05-28-2018 03:22 AM
dragmkd
10-28-2005 10:15 AM
