Test? ignition control module...93 100csq
On a 93 100CSQ I'm getting a no start..No power to coils / spark plugs. So recently I pulled off the ignition control unit off firewall. I checked for continuity between 3 prong side (E1, E2, E3) and the four side (11, 12, G, and 13)...I got 10 ohms between E1 and 11,12,G,&13 and 10 ohms between E2 and11,12,G&13....and 10 ohms between E3 and11,12,G &13... Now should I be getting continuity between G (ground) and E1 E2 & E3 ? I'm thinking not. Is the module bad? Oh, I did check the Ground tab in 4 prong connector to a ground on car with mutimeter and I did have a good ground. I'm unsure of correct test procedure ...any thoughts?
trailertravis13
01-21-2006 06:55 AM
Stoney
VAG-COM Discussion
05-18-2004 04:46 PM
Stoney
05-18-2004 04:44 PM
