tranny question
What is the ATF fluid capacity of the auto tranny in 95-97 A6's?
How do you drain entire tranny (not just pan)? They guy who flushed my transmission last week claims he flushed 14 qts of ATF. How did he do that without removing transmission?
Ran it through all the gears, drained it, refilled, etc, etc, until the fluid started to clear up? But that takes alot of time to do that. Another way, he may have used a vampire pump in some way to remove more fluid than just draining the pan but who knows.
to do this. Since the fluid in the torq converter will not come out thru a simple drop the pan exercise. You can do a complete change in fluid with a machine that hooks into the tranny cooling lines (running to the radiator).
I suspect he used that much because you have to keep feeding it, of course a certain amount will mix...so they just keep feeding it new fluid until the fluid coming out is reasonably clean again.
eigenvector
09-09-2006 03:15 PM
t0mt0m
08-25-2005 02:17 PM
CLeonard
03-29-2004 05:12 AM
