Transmission additives?
My transmission on my 94 Quattro 125K has been whining since I got it above like 15-20mph.
Has anybody ever used any of those transmission additives they make? Do they work or just make it worse?
What about that engine oil gunk remover stuff you put in the oil, let it idle for 5 minutes, then change the oil? Does it really get all kinds of gunk out? Is it damaging?
Thanks!
Thanks!
Is the front diff at the correct level?
Lotsa talk about the ATF here, but none about the gear oil.
If your car is FWD, your trans has an automatic part that takes Audi ATF, and a differential half that takes gear oil.
If your car is quattro, your trans has an automatic part that takes Audi ATF, a front differential that takes gear oil, a center differential that takes gear oil, and a rear diff that takes gear oil.
A whine is more likely to be produced by a low diff than a low ATF level.
I would use a tablespoon of sugar.
I am sure any other additive will provide similar advantages.
In other words additives budget is mostly consist of advertisment money. On the other side Mobil or Pentosin spends millions on research.
A4_1.8T_1999_5ECT
12-11-2005 10:01 AM
Mr. Head
11-20-2004 03:16 PM
