turn signal issue
I've got a 98 A6 and the turn signals just stopped working properly. In addition, the emergency flashers also don't work properly. The symptons are as follows: when I indicate left or right, the blinkers either don't work or work for 1-2 blinks and then stop. The same is true when I press the emergency flasher button.
Is this a turn signal relay issue? If so, how does one replace the turn signal relay?
Thank you in advance for your help.
Jeff
Jeff
J2 Emergency Flasher Relay is located behind the instrument panel, accessed by removing the instrument cluster.
J2 gets power from the emergency flasher switch and then provides power to the turn signal switch and back to another part of the emergency flasher switch.
I have an extra E-flasher switch that I might consider parting with.
<img src="http://i100.photobucket.com/albums/m32/JunkyardCars/misc/FlasherRelay.jpg">
yup just follow what corne's said, i also replaced the emergency flasher button which is located behind the instrument panel.
__________
turn signal switch | auto parts | ~jimmy king~
__________
hi jeff.. right now i do have the same problem like the one you posted before about turn signals and flashers not working in an audi 99.. i would like to ask if its only the flashers button or its a relay with the flashers button in it? thanks..
chapman62083
01-25-2012 10:51 AM
Gen4200
07-01-2005 07:09 AM
A4_b4_996
12-20-2004 07:22 AM
