Is VAG COM Release 409.1 or 311.2 and a 'dumb' interface enough for a '97 C4?
From what I've read from Ross-Tech the newer software and interface(HEX/CAN) takes advantage of the newer/more elaborate C5/C6 platform but not hte C4. Trying to make a decision if I just need to get he 'dumb' interface in ebay and buy the software license from Ross-Tech. Working on a limited $$$. Thanks!
I just did this. Now I had zero codes to reset but it would allow it (the free version) had I needed to do it. The only problem I have (if it is a problem) is that I can only see the controllers listed below. I also have comm problems at times. I will be setting up a new Laptop specificaly for use with the Vag Com and I am hoping the comm problems go away. Now can someone tell me what controllers I should see in on a 1994 100cs. Thanks
Address 01: Engine
Protocol: KW1281
Controller: 8A0 906 266 BV
Component: 6 2,8 2V MPI V6AC39 D0E
Coding: 00002
Shop #: WSC 34838
Address 02: Auto Trans
Protocol: KW1281
Controller: 4A0 927 156 Q
Component: AG4 GETRIEBE 01K D81
Coding: PMC 0
Shop #: 0260002286
Address 03: ABS Brakes
Protocol: KW1281
Controller: 4A0 907 379 A
Component: Bremsen-Elektronik
Coding: 0265100056
Shop #: BB 33837
Address 08: Auto HVAC
Protocol: KW1281
Controller: 4A0 820 043 F
Component: Klima-Vollautomat D05
Coding: 00004
Shop #: WSC 125974
Address 01: Engine
Protocol: KW1281
Coding: 00002
Shop #: WSC 34838
Protocol: KW1281
Coding: PMC 0
Shop #: 0260002286
Protocol: KW1281
Coding: 0265100056
Shop #: BB 33837
Protocol: KW1281
Coding: 00004
Shop #: WSC 125974
aluminumpork
12-31-2005 02:00 AM
