water drain hole? 92 100csq
After it rains lately I get water pouring onto my foot. Someone said there is a drain hole under the car (by the fire wall?)that must be plugged up. I have no clue what I am looking for or even how this water gets into the car. It seems to come out above the pedles. I was under the car the other day and I saw nothing. Anyone know the location of this drain hole? Please advise as I don't feel like breaking out the shop-vac every time it rains. Thanks if you can help. Pat
Check the...
Open the hood there is a cover between the fire wall and the windshield. Remove the black cover held by clips. Look in the crevace by the driverside fuse box there is a drain there, and check the area by the passengerside respectively. Mine was full of decaying debris. I cleaned it out and used a coat hanger to roto root the tube. It solved the water in the cabin.
Check your computer for water.
Be very careful. This is how I lost my computer on my 100S. Check to make sure it is not underwater. Mine obviously was for a long time as evidence of the corrosion.
The Audi carpet will hold water for a LLLLLOOOOONNNNNGGGGGG time.
Good luck,
Khris
Good luck,
Khris
Heimir Baldursson
Audi 100 / A6 (C4 Platform)
07-20-2013 09:50 PM
hdtrc
03-29-2005 07:09 PM
