water leaking...
im having the worst luck w/leaks in my 94. it seeps in through every light fixture above the doors, on the right and left side of rear seats. also seeps down in the driver floorboard and passenger floorboard. also from the front passenger door where door meets hinge. anyone else had problems such as these? i don't know what to do...i've tried sealing stuff up.
are you sure that your sunroof drain hoses are conected.As you explained you are getting leaks from 4 corners ef the car and that usualy happens when drain hoses are clogged or fallen off the sunroof frame.
Joey T
02-13-2008 07:59 AM
RalliSport Ron
11-19-2003 09:45 AM
