well i've cut everything down to 3 problems
1. buy new coolant reservoir tank...
2. figure out what the hell is wrong w/ coolant temperature sensor(if related to leaks from sensor, which i doubt)
3. fix AC so i can stop using rags to wipe windshield [ac not blowing out windshiel defrost](optional since it is not causing the CEL to go on)
3.5 find a reliable mechanic in greater seattle area to fix #2 and possibly #3 for a normal price(yes i know i said 3 problems...)
HERE ARE THE ERROR CODES, AND IN CASE THERE ARE ANY MECHANICS HERE(or reccomendations on who to call) please help!
NOTICE THAT ADDRES 01 AND 08 ARE THE ONES THAT ARE CAUSING ME PROBLEMS
VAG-COM Version: Release 311.2-N
Chassis Type: 4A - Audi 100/A6 C4
Scan: 01,02,03,08,15,17,25
Address 01 -------------------------------------------------------
Controller: 8D0 906 266 B
Component: 2,8l V6/2V MPI OBD2 D01
Coding: 01242
Shop #: WSC 02324
2 Faults Found:
16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
P0116 - 92-00 - Unknown Error Elaboration
16785 - EGR System: Insufficient Flow
P0401 - 93-00 - Unknown Error Elaboration
Readiness: N/A
Address 02 -------------------------------------------------------
Controller: 4A0 927 156 AL
Component: AG4 01F 2.8l2V USA D26
No fault code found.
Address 03 -------------------------------------------------------
Controller: 4D0 907 379 J
Component: ABS/EDS BOSCH 5 7679
Coding: 0265109024
Shop #: BB 37679
Address 08 -------------------------------------------------------
Controller: 4A0 820 043 K
Component: Klima-Vollautomat D05
Coding: 00162
Shop #: WSC 23250
1 Fault Found:
01272 - Positioning Motor for Central Flap (V70)
41-00 - Blocked or No Voltage
Skipping Address 15-Airbags
Address 17 -------------------------------------------------------
Controller: 4A1 919 035 CJ
Component: C4-KOMBIINSTRUMENT D20
Coding: 00262
Shop #: WSC 05701
No Faults Found
or DTCs not supported by controller
or a communication error ocurred
End -------------------------------------------------------
P.S. I have changed my coolant temperature sensor about 3 months ago and I don't know why the problem keeps reappearing...
Coding: 01242
Shop #: WSC 02324
2 Faults Found:
Readiness: N/A
Coding: 0265109024
Shop #: BB 37679
Coding: 00162
Shop #: WSC 23250
1 Fault Found:
Coding: 00262
Shop #: WSC 05701
No Faults Found
check the voltages from the sensor hot and cold to verify it's operating properly.
double check you changed the right sensor...G62 is on the driver's side near the firewall, but can be confused with F76 on the passenger side.
<center><img src="http://www.12v.org/engine/images/rear.gif"></center><p>http://www.12v.org/engine/index.php?section=cl&view=rear
you're looking at the rear of the engine in this view, so the drivers' side is on the left.
see also:
https://forums.audiworld.com/a6100/msgs/55976.phtml
https://forums.audiworld.com/a6100/msgs/55532.phtml
see also:
this is probably why my coolant temp is always DOWN...(i mean the gage is all the way down) except when i'm on freeway for a bit it raises but then goes back down...?
P.S. so i'm gonna buy the F76 sensor which is part number 034 919 369C(acquired from the link u gave me
) that exact one should work for me right? (buying that and coolant reservoir tank from autohausaz and gettin free shipping
.. hopefully this will stop the leaks and stop the check engine light so then all i have left to go to the mechanic with is the damn ac not blowin thorugh windshield problem...
Djole
Audi 100 / A6 (C4 Platform)
9
09-26-2005 06:13 PM
Bryans12v
11-05-2002 10:05 PM
