Whats the right antifreeze to use......
in a 92? I've got the green fluid in it and couldn't remember if I could just pick some up from the local auto store or if I needed something Audi Specific. If I rememeber correctley the early model can use any generic? Thanks in adavance.
Answered my questions about the difference between red/green fluids, organic acid inhibitors vs. silicate inhibitors, etc.<ul><li><a href="http://www.popularmechanics.com/automotive/sub_care_sat/1272436.html">antifreeze explanation</a></li></ul>
The bottom line (in my opinion), make sure it AT LEAST says "Safe for Aluminum Engines" somewhere on the bottle. The debate whether to go red vs. green, OEM vs. "similar product" is one that has many opinions here. However, I would not put anything (green or red) that isn't specifically labeled safe for aluminum in there at all. Hope this helps!
~scrogers
~scrogers
ensure that you use the green/blue Pentosin coolant. Or do a complete flush and the you can use the updated red Pentosin coolant.
Does the type of coolant I use matter as long as I used extended life? Can I mix whats in there.....
Biscuit141
Audi 100 / A6 (C4 Platform)
07-25-2009 09:02 PM
UrSoccer_mobileĀ®
10
11-05-2002 10:39 PM
JazzGuitarist
10-24-2002 09:22 AM
