wheel bearing
anyone ever change a front wheel bearing? can't find anything on my bently (CD) about it. is this job better left to shop?
Jim
92 100 CS 180K (the one with noisey bearing)
86 5000 S 185K, (just keeps going and going)
Jim
It talks about "with bolts supplied", "also bolt and thrust washe". It seems this is being done on the car, which means no strut removal or taking to machine shop.
Are these instructions from a kit of some sort? Where do you get it? Or are they standard bolts, washers, etc?
Designed to R&R the bearing "on-car".
Problem is, most wheel bearings have been in a while, and require much more force, than the special tool can deliver! Plus you need other large tools just to operate the special tool! That 3/8 drive ratchet pictured, isnt gonna cut it. I know, I've used the special tool, and you do 4 bearings, your physically worn out! Because you provide the force needed buy turning the tool, to press out the bearing! ;O)
I've since purchased 2 hydraulic press's! 1-10 Ton & 1-20 Ton. The Hydraulic press's make wheel bearing R&R much easier!
The instructions are what come with the tool. I post them to give folks an idea of whats involved to R&R wheel bearings. Newer Audi's have the bearing housing "bolted" to the upper strut. Un-bolt bearing housing, find a shop who can press the bearings, and you'll save yourself some time & cash! ;O)
i'll probably have the job done, but just in case i decide to try it, where do you buy the tool? is it expensive? i have 1/2 and 3/4 rachets, plus air wrenches and a long pipes for leverage.
The Red October
21
09-06-2007 04:02 PM
520
07-05-2006 10:07 AM
FixedWing
17
10-01-2004 10:48 AM
canonicalman
01-18-2004 12:50 PM
