Wheel spacers...does it matter if they're hubcentric or not?
Bought a set of Shur Grip Z (model SZ329) cables for snow traction because where we ski there can be mandatory "show chain" useage regardless of if you're 4x4 or not. I'm running 205/65-15's, and there wasn't sufficient clearance between the front strut tie-rod arm and the inner sidewall. So, I bought a set of HR longer (35mm)wheel bolts and 8mm thick spacers.
Installed the spacers and wheel bolts, and the snow cables fit great, with just enough clearance.
My question is, I bought a set of non hub centric spacers. They fit fine, the wheels mount fine and there's no vibration at any speed. Can I run them? Or, do I need to buy the spacers with the hub centric shoulder?
Without the hubcentric spacer the entire weight of the vehicle will be resting on your lugs.
I would never use anything besides a hubcentric spacer if I had to, but if they're only going to be used occasionally when you're skiing I'm sure you could get away without them. I'd still try to find a cheap set of hubcentric spacers though.
Point taken. I'm ordering them with proper centers now.
The local German parts place just happened to have a "returned" set, so I was hoping to take advantage. But, it's not worth it if it becomes a safety issue and the ski mountain is a 3.5hr drive away. That's a lot of hours on the road at speed!
Jiggsy
18
11-13-2007 11:12 AM
horizontal8
05-12-2006 08:47 AM
paulroad
07-18-2005 04:47 PM
