Where is the MTFS located at
Re: multifuction temperature sensor I'm guessing
Well, I did more troubleshooting today. To test the compressor and make sure is working ok, I connected it directly to the relay switch (267)on position 9, the compressor turns on. When I took the relay out and leave the positive wire connected to the compressor, it remains on. Put the relay back without the hot wire to the compressor, then it does not work, so this tells me the Relay switch (267) is busted?, does this relay also control the coolant warning light?
thanks
thanks
Position 9 (in the Aux Relay Panel) is the A/C Clutch Relay, J44. If your A/C compressor runs by...
bypassing the relay, then the relay is probably bad. No, it does not connect directly to the coolant warning light. It is connected to the A/C Control Head (E87).
Where is the MTFS located?
Thanks A6gary for the suggestion. I will go ahead and get this relay. Now can someone please tell me where the MTFS is located? I really appreciate your input.
michael0156
08-04-2004 07:49 PM
jucandoit
01-30-2003 01:09 AM
