Windshield wiper problem (fluid isn't being squirted)
Yes, I have a full reservoir...
I can hear the pump running , but nothing comes out. not even the headlights.
Thanks.
1992 Audi 100CS
Thanks.
1992 Audi 100CS
Get someone to squirt the washers from the inside, then have a look to see if you are loosing water... u might have a broken pipe somewhere. Otherwise I guess that though the motors run, they r a bit tired.
You probably have a broken hose somewhere, they get brittle with age and heat. Do you see a big puddle of washer fluid on the ground after you run the pump?
Could be your washer check valve.<ul><li><a href="http://www.audipartstore.com/audi_washer_check_valve.html">Washer Check Valve</a></li></ul>
Thanks for the help.
I did have a broken hose right under the hood where the washer jets are. (couldn't see the fluid coming out until I tried it with hood open)
I also just replace a headlight washer (was smashed) with a new(er) one, and no fluid coming out.
I noticed that they can be pulled way out and makes a gurgling sound. Is there a procedure to bleeding the washer lines?
coasTTal
09-11-2005 08:28 PM
