Wiring radar detector into 97A6QA
Old 03-27-2002, 08:15 AM
New Member
Decolliber's Avatar
Default Wiring radar detector into 97A6QA
I want to wire my Valentine 1 directly into the car, so I dont have cords flopping around. I plan to run the wire from the bottom middle of the windscreen left over to the driver's side and under the dash to a power source and ground. Ideally I would like to use a power source switched on with the ignition. Has any one done this? What would be the best accessible power wire to tap into?
Old 03-27-2002, 09:58 AM
beep-beep's Avatar
Default I did it with Bell. You can find nice howto in the tech. section.
<center><img src="http://pictureposter.audiworld.com/14894/beep-beep.jpg"></center><p>
It looks very stealth. But I still looking to make it almost invisible for cops.
I think I used the rear wiper fuse to connect the +12V. The detector is on, when ignition is on. Unfortunatly I do not have a switch to switch it on/off manualy. I am planing to install additional "fog light switch" on the panel and use it to turn the radar off, when I am in the city and do not use it. I think the V1 has this switch.
Old 03-27-2002, 11:17 AM
New Member
Decolliber's Avatar
Default Re: I did it with Bell. You can find nice howto in the tech. section.
Thanks. Where is the "tech section"?
Old 03-27-2002, 11:30 AM
QCRAZY's Avatar
Default Follow the link...
<ul><li><a href="https://www.audiworld.com/tech/index.html">https://www.audiworld.com/tech/index.html</a</li></ul>
maxnharry
04-10-2021 01:41 PM
C6Silver
Q7 MK 1 Discussion
12
07-25-2013 09:02 PM
Small Town Terrorist
Audi Original "S" Cars
9
05-31-2005 05:38 AM
LWLam
08-15-2001 05:52 PM
Quick Reply: Wiring radar detector into 97A6QA
