10v I-5 Turbo IM with Secondary Injectors and ECU
Great for a turbo conversion on your 80/90, 4000, CGT, or if you just need to add more fuel to your system. This system makes it possible to put a turbo engine in your car without nightmare of swapping in the turbo fuel system. You simply use your stock CIS system, then when you need more fuel under boost, the secondary injectors kick in. I have run 20 psi through this system with no problems. Depending on your intercooler and ignition system, you may see different results. You will need a computer, preferably a laptop, running Windows 9x to program the ECU. All of these items are included in the price: Intake manifold with 5 secondary EFI injectors, fuel rail, fuel regulator, some fuel lines if you want them, intercooler with the small hose output, ECU with settings, and second fuel pump. I can sell just the IM and ECU together if you are not interested in the other stuff. I am selling this stuff because I am going to a full EFI system with a header. All of it together for $650.<ul><li><a href="http://www.geocities.com/jeg1976/car_home.html">http://www.geocities.com/jeg1976/car_home.html</a</li></ul>
<center><img src="http://pictureposter.audiworld.com/13040/4000_4.jpg"></center><p>Sweet car! Are you in the Denver area? You should come out to the track.
audifreakjim
05-30-2005 11:50 AM
BigMouse
12-08-2001 06:37 PM
audifreakjim
10-25-2001 01:17 PM
CharlieGSanD
03-21-2001 10:57 AM
