1984 dash lights, non-digi cluster.
I'm posting this to contribute to the greater good of this forum. All you folks w/ digi-dashes, this probally won't assist you w/ yours, but may apply to those years other than 1984 that have the "regular" clusters.
Following is the order of the small indicator/warning lights, the small 1/4-turn-in bulbs on the back of the cluster. Three lights have seperate wires leading to them, the rest have bulbs only on the flexible circuit board back there.
In my Bentley, these wern't listed, and on the cluster circuit board are numbered 1-12. The numbers are on the circuit board, viewed with the cluster OUT and removed, not from inside the cab sitting in front of the dash.
1-Shifter, has wire leading to it
2-Oil warning, bulb only
3-Turn signals, bulb only
4-Hazard, bulb only
5-Oxs, bulb only
6-Water temp warning, bulb only
7-NOt sure, sorry....
8-Heated seat indicator, wire leading to it
9-Bright lights, bulb only
10-Seat belt, wire leading to it
11-Emer Brake, bulb only
12-Defroster, bulb only.
4-Hazard, bulb only
5-Oxs, bulb only
kpisafterme
A4 (B7 Platform) Discussion
10-17-2006 06:02 AM
SCarGo02
36
10-21-2005 01:42 PM
fanta4
01-22-2003 04:10 PM
