4x108 ---> 4x100
#12
Here's why:
4K subframe:
<img src="http://www.vwaudirally.com/auditech/quantumvs4k/subframe4k.JPG">
Quantum subframe:
<img src="http://www.vwaudirally.com/auditech/quantumvs4k/subframequ.JPG">
4K control arms/hubs/bearings/axles:
<img src="http://www.vwaudirally.com/auditech/quantumvs4k/suspension4k.JPG">
Quantum control arms/hubs/bearings/axles:
<img src="http://www.vwaudirally.com/auditech/quantumvs4k/suspensionqu.JPG">
4K brakes:
<img src="http://www.vwaudirally.com/auditech/quantumvs4k/brakes4k.JPG">
Quantum brakes:
<img src="http://www.vwaudirally.com/auditech/quantumvs4k/brakesqu.JPG">
The biggest issues are that the bearings have different inside diameters(75.07mm on the 4K, 68mm on the Quantum), and the hub shafts have different diameters to fit the accompanying bearing, so the Quantum bearings won't fit in the 4K knuckles, and the Quantum hubs won't fit in the 4K bearings. Then you have the issue of brake rotor diameter(245mm on the 4K, 239mm on the Quantum), and the offset is different. Not to mention that the Quantum caliper carriers mount to the back, and the 4K caliper carriers mount to the front. I can continue, but I think you see where this is going.
4K subframe:
Quantum subframe:
4K brakes:
Quantum brakes:
#13
Do you intend to drive this car hard? track days?auto-x rallyX? if the answer to any of the above is yes DO NOT DRILL you open your self up to cracking, DRILLED HOLES IN PARTS WEAKEN THEM! andhub cracks are difficult to spot.
#14
there's plenty of material on a hub to allow for another set of lugs; it's not as though they'll be drilled right next to the existing holes, nor is it akin to cross-driling brakes, which i definitely do not recommend. as i said before, a friend of mine did it to his 4kq, and he's FLOGGED that car. no problems at all from the hubs.
it's definitely best left to a machine shop, though. a DIY job probably will crack the hubs.
#15
The only reason I brought it up was when I was working at Motor Sport Service, and al oag was racing the vw's, hub and upright cracks were a problem and those parts had also been shot peened- drilled holes , especially threaded holes, create tremendous stress raisers.
Thats all
Thats all
#16
it sounds like you're talking about full-on race abuse, and i agree. you'd be stupid to drill a different bolt pattern into a race car's hub. it's fine for spirited driving or autoxing, though.
A4wheelin
04-24-2007 08:18 AM
CS_CGT
Misc. Models Discussion
14
07-24-2000 02:16 PM
