'87 4000 S coil springs
Old 12-30-2008, 07:53 PM
CWM
New Member
CWM's Avatar
Default '87 4000 S coil springs
Hi, I'm new here and recently bought a 1987 4000 S non-quattro that had been lowered. The springs were chopped and the car is so low it scrapes over bumps and I can barely get around town.
I had no idea how hard it would be to find replacement springs. I am not looking for lowering springs, just want it back to stock height. Someone who does rallycross found me a set for a goog price but it turns out they were from a quattro, and he said he looked it up and that it wouldn't work for my car (does anyone know if it's doable? I feel like anything would be better than the way it is now...)
I guess I'm just looking for someone to steer me in the right direction. I live in Portland Oregon. I've called auto part stores and they either couldn't get the parts or told me they would be insanely expensive, and I've called the junk yards with no luck.
Also the front passenger-side strut is blown so I bought new front struts to put in when the suspension gets fixed, and am now looking for just the springs (all 4), is this accurate? Some people I've talked to said they can be done separately but I thought someone else said it was all one unit.
I have plenty more questions about my new car, little things that need to be done but for now this is the most important thing as I can barely drive it. Thanks so much for any help you can give me.
Old 12-30-2008, 08:10 PM
kelbrig1's Avatar
Default Hmm, those might be tough to come by for a non q. As for the struts..
I know at least the fronts should be done together since the whole upright has to come out. I'm not familiar with the rear of non Q's though. There is a guy out in Portland on other audi forums that may be able to get you the springs. Derek is his name. I should have his email if you want it.
Old 12-30-2008, 09:05 PM
Blewtoon's Avatar
Default front springs should be the same
you could use the rear springs from a cgt if you can locate them
Old 12-30-2008, 09:12 PM
kelbrig1's Avatar
I don't think the front springs for a 4cyl fwd are the same for a 5cyl quattro
Old 12-31-2008, 03:52 AM
Junior Member
PartyBoyRacing's Avatar
I was thinking of chopping mine & may consider a trade. Can you post a pic of the ride height?
Old 12-31-2008, 04:57 AM
Blewtoon's Avatar
They may be stiffer. but the basic setup is the same.
Old 12-31-2008, 05:04 AM
New Member
billlebob's Avatar
Default Probably not as hard to find as you might think... if you know the right people.
Go to vwvortex.com, to the Fox forum. Look for a user named Longitudinal. He may have a set. He seems to have one of everything. I've thrown out 3 sets in the last few years.
Old 12-31-2008, 06:52 AM
jitsu303's Avatar
Default Post an ad on the classifieds here and..
...on Audifans.
You'll get something. There is always Chris at ForceFive too..you'll pay a bit more and he may exaggerate the condition slightly.<ul><li><a href="http://www.force5auto.com/">forcefive</a></li></ul>
Old 12-31-2008, 07:57 AM
AudiSport4000's Avatar
No? I would think they would be. No ETKA to confirm though...
Old 12-31-2008, 10:04 AM
4000fixes's Avatar
i just sold a set of H&amp;Rs that would have been perfect for you...
Quick Reply: '87 4000 S coil springs
