adjustable voltage regulator
If you have voltage supply problem, find the source of the problem.....typically it's bad battery cables that are a combination of old, corroded, have had bogus connectors installed, and are too small in diameter to carry the load of all the electronics.
Simply replacing the cables will amaze you with the improvements you'll get.
He did some experimenting and found that all regulators are not created equal. Choose your brand, choose your voltage.
http://www.humanspeakers.com/audi/alternator.htm
a combination of wierd charge line routings and Bosch alternators losing voltage in time. Alternators thould be supplying a steady 14.4v at the battery. And yeah, I'd try a rebuild shop. I used to work at one, and all the old Boschs we did were sent out with adjustable regulators.
i did forget to mention this is rebuilt.
but i dont know what an adjustable regulator looks like and if i have one or not
my voltmeter does say 13-13.5 volts most of the time
i am still trying to figure out what cause the other alternator to blowup inside
at 13.5 V, I'd definately recomend an adjustable regulator. The regulator is the little black circle with the two screws mounting it on the back of the alternator. An adjustable one will have a small (like 1mm) hole in the back of it. Inside that hole is a potentiometer (little plastic screw), which will adjust the output when you turn it.
Check the output at the back of the alternator, and at the battery with a digital meter. That'll be most accurate.
And seriously consider replacing the battery cables with large diameter ones, like "0" gauge.
It makes a huge difference, and even your dash gauge will read higher.
A6George
Audi 100 / A6 (C4 Platform)
04-17-2008 10:00 PM
BoostFrenzy
07-22-2003 02:19 AM
