Air filter under the fuel pump?
I was dicking under the hood today of my 86 4000csq. Was looking for the air filter, and found it under the fuel pump. Seems kind of strange to me. Is the fuel pump hard to remove? Do I have to disconnect any lines?
That's called the fuel distributor. I haven't actually done it myself (getting a K&N soon, so I'll figure it out then) but servicing the filter is pretty common so it should be possible to do without too much drama.
Check <a href="http://www.humanspeakers.com/audi/airfilter.htm">Huw's air filter page</a>
Just pop the clamps, pry up the front of the lid and remove/replace the filter. That's it. Your fuel pump is located near the fuel tank, by the way, along with your 2 fuel filters.
The fuel pump is underneath the car under the driver-side back seat passenger. (Start the car and look underneath, you can usually hear it buzzing) Round cylinder with wires attached.
Remove headlamp, release "clips" surrounding the airbox top, tilt up the lid about 2 inches, and swap the filter..
It was a lot easier to change when you had the entire CIS system ripped apart for drying and the intake off. It was still a PITA to get at that side clip..
paulroad
Audi allroad
12-23-2008 08:50 PM
sic_fast
02-05-2007 02:48 PM
wisconsin_quat
10-10-2006 12:16 PM
Matt Devo
16
07-08-2005 10:34 AM
