Air/Fuel mixture
Air/Fuel mixture
Does anyone know where to get the wire harness to use to plugin to the end of the fuel distribution block to test the amount of air/fuel going in? I know that you have to use a multimeter and the reading should be around 1.something. Then you have to adjust the 4mm hex screw to adjust the mixture. Right now I dont even get 200mi to a tank of gas. My car is setup for the altitude and I need to adjust it to sea level. Can anyone help?
Here's a few links...
www.zelenda.com and www.zdmak.com are two places that sell specialty VAG tools and cables for CIS system measurements. I wouldn't be surprised if the cable is more costly than doing it by feel or paying a shop, but I've attached a good reference link on the DIY.<ul><li><a href="http://www.sjmautotechnik.com/ficis.html">http://www.sjmautotechnik.com/ficis.html</a</li></ul>
you can just attach a multimeter to the oxygen sensor when the car is running....
essentially doing the same thing as a air fuel gauge. Don't know what normal would be but someone else might.
oldyellar
12
04-11-2005 12:49 AM
Small Town Terrorist
Audi Original "S" Cars
08-22-2004 05:08 PM
S4stylin TMK
11-14-2002 04:30 PM
