audio q`s?
Re: audio q`s?
The front dash speakers are accessible if you remove the lower part of the dash on the drivers side, and the glove box on the passenger side. The speakers held by screws on the bottom side, under the dash.
Also, if I remember correctly, the speakers are physically attached to the speaker grille assemblies, ie they don't just rest under the grilles on the dash.
The rear speakers, I'm not as sure about.
In my experience, if you're putting in aftermarket speakers, some modification may be required to get the stock speaker grilles to fit with the new speakers.
Rear speakers, new style interior.
Beleive it or not, the top grille cover 'unscrews'.
Grab the speaker cover/grille, and carefully turn in counterclockwise.
May be easier if you have the complete back deck loose, so you can grab front and back of the speaker at the same time..
(When I mounted 6x9 speakers in the back, I cut holes in the metal deck for the speakers, leaving just the stock grilles in the carboard deck for the sound to come through.
Speakers were much more solidly mounted, and had much better bass as they were working into the whole trunk area, instead of the small area under the cardboard deck.)
Black Sunshine
08-31-2005 11:09 AM
CapitalAudi
9
04-27-2003 08:23 AM
Peter A.
06-28-2001 07:04 AM
