Can't figure out if fuel pump is the problem
My 4000cs won't start so I pulled the line off the fuel pump and cranked it over and gas comes out while it's priming, but not while it cranks, then when I turn the ignition off it squirts some more out. Any help would be much appreciated
Have you checked to see if the fuel pump relay is clicking on while you crank? It could be a bad relay (cracked solder joints), but the fact that it primes leads me away from that. The next suspect would be the hall sender inside the distributor. If it's bad it won't give the "engine is cranking/running" signal to the relay, but the relay itself would still prime.
It could be the fuel pump, but the fact that it primes is again unusual if that's what it is.
Unfortunately the only thing you can do with the hall sender is to rule everything else out and then replace it. Replacing it is the only diagnosis for it that I know of. If you replace it, just get the whole distributor as it's not much more than the sender by itself.
-Rog
-Rog
How does the fuel pump sound when its running? A nice even hum? or a squealing pig on its last leg? CIS requires alot of fuel pressure to operate properly and if it never reaches that mark there is a good chance the injectors arent even opening. Just something else to consider.
I don't feel the smartest but I am relieved. Thanks for the help guys. It wasn't squirting fuel while it was cranking cuz the battery was pretty drained. after spending quite some time on it I noticed my clamp holding the intake boot on was loose, so there was a small opening at the seal. That was my problem. This car makes me miss working on my Japanese cars but damn it looks good.
That's good! Always nice when it's something simple.
Yeah, you'll come to realize just how sensitive they are to vacuum leaks and other seemingly minor things. The funny thing is, you'll probably love it more the more you have to work on it. That's what happened to me and now I have a whole collection.![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
-Rog
-Rog
NJRoadFan
03-27-2008 01:22 PM
DoraBug
05-10-2005 04:17 PM
