Cant get the Slave cylinder out of my 4000csq HELP!!!!!!!
Does anyone have a idea the slave cylinder seems like it is frozenn in the bell housing. The thing wont seem to move. anyone have a suggestion or maybe a easy way.
Thanks]
Kris
Thanks]
Kris
The slave cylinders are known to rust in place. Often requiring the entire gearbox to be pulled.
You might try pushing the clutch pedal down to see if the hydraulic pressure of the
system is enough to budge the slave.
Then see if you can get it rotating. While rotating, see if you can shimmy it out.
Their PITA's, I know, I've done a few.
Also spray some good penetrating oil like
Liquid Wrench inside the pin hole, so it goes down onto the slave and maybe helps loosen it. Block the other end of the pin hole so you oil doesnt go shooting out the other side.
You might try tapping on it with a hammer.
See if you can get it to break loose tapping it forward into the gearbox.
|skolnick
11
12-03-2006 09:56 PM
