DIY rear bar for a 4KQ??
was thinking about a rear bar for the 4KQ by using a front bar turned around - Given the rear suspension is the front turned around, is there any reason why a front bar from say a CGT wouldn't work on the rear of a 4KQ? I am thinking the bar would be behind and could use the same end links as the front - the only work would be to manufacture the bushing mounts and bolt/weld to the chassis. This would also give the CGT crowd something to do with their old bars after they upgrade to the larger 4KQ bar :-)
I was at Gingerman Raceway a year or so ago, and a red 10vt 4kq with Urq fenders had a front bar in the rear. Welding is required for the brackets, but he didnt go into detail.
got some snow between it last winter and when it expanded it ripped a hole in my subframe where the weld was. It can be done though with the same peices from the front.
stormchaser
07-23-2004 04:42 AM
White Coupe
04-14-2002 05:30 PM
White Coupe
03-27-2002 10:13 PM
