DIY White Face AUX (2" VDO) Gauges
#11
my email is nielshavberg@adslhome.dk
Do you use any special paper for printing?
Thanks alot in advance :-)
Btw, have you made the speedo/RPM instrument faces in white also?
#12
Lane Shark
<ul><li><a href="https://forums.audiworld.com/4000/msgs/86198.phtml">https://forums.audiworld.com/4000/msgs/86198.phtml</a</li></ul>
#14
They are basically the same, except the main cluster has the quattro logo across the faces. As for the paper type, any white lable stock is good enough. I just used Avery full sized sheets..
This is just to show you what they look like, DO NOT print this file. (too low res for a clean print)
<img src="http://pictureposter.audiworld.com/80494/cdn_cluster4kq.jpg">
#16
Originally on sticker paper, but I had them reprinted on vinyl. The sticker paper started to bubble after a few months. Plus I was able to get a much closer match the silver faces of my Autometer aux. gauges. Cool little upgrade on the cheap.
J.
Low-res pic, they look white but they are light silver metallic. Also added a 130mph mark on the dial, as well as rounding the edges on the gas & temp gauges.
<img src="http://pictureposter.audiworld.com/21637/cgtgauges2.jpg">
J.
#20
He was planning on making these and selling them, so he did not want to post the file. But seeing as how he has not gotten around to it, he may not care anymore. Give me a day or two.
J.
P.s. GT Style you got a set, so it's not like my bro is totally opposed to sharing. Now all you have to do is move to the US so your gauges will be accurate in MPG rather than KPH.
J.
