Doors handle fix?
These are problematic. They break, and need replacement or good repair.
Is the trigger still on the car? if the depressing release [I'm calling it the trigger] is permanently down, then you'll need to pull the handle and see what's not working.
Please do a Search on "Doorhandle repair" and you'll find much there about it.
You'll probally end up with a collection of working and non-working handles like the rest of us! Every handle is different, so not so many interchangable parts.
Re: These are problematic. They break, and need replacement or good repair.
Thanks for the help; the trigger works, but the inside lever to open the door is not connect to anything...must have broken. I was trying not to have to take the door panel off. I have other problems with "my girl" as she broke a hard brake line over the weekend and barely got home. So I am trying to replace the lines as we speak - suggestions? THX
there's a couple of rods in the door. One probally came apart
And, once you get inside the door, you may find other stuff connected that needs "tweaking". something made that rod disconnect, look for the reason. I'm betting it's in the door handle.
The brake issue..... worthy of another post here. also can do a search and see what others say.
I'm a reasonably good mechanic, however there are some REAL experts on this forum.
