electrical
I'm having trouble with a circuit on my car it keeps burning the fuse and i cant figure out why i have a 1986 4000cs q the fuse is #12 it controls the blinkers, reverse lights, instrument cluster and its supposed to control the radio but it doesn't. If you have any suggestions pleas help also if you have a whirring diagram i don't have one. Thanks
Being the auxiliary, you'll find that POs have chopped into it, created bad earths, high resistances, and all sorts of stuff.
From all the woes I had with mine, I'd guess it was something to do with the stereo not working - someone has played with the wiring behind the dash part. Disconnect and tape up all the non-essential stuff, drive for a while and see if a fuse pops. Unfortunately it could be anything - water getting into your trunk and shorting, crusty light cluster circuit boards - anything!
If you are blowing fuses for anything that is in the back of the car, check the wiring on the left trunk lid hinge.
Wiring there often gets tangled up and mashed or pinched, resulting in all sorts of weird problems.
I finally figured that I only blew a fuse when I went to backup (revese lights were shorted out). Once I fixed the problem in the hinge wiring, all my tail lights worked better too!
Luxus Panzer
12
05-15-2007 02:13 PM
wisconsin_quat
03-08-2006 10:33 AM
