Euro light wiring harness from Blau- worth the $$$$
I am curious about something- is the "plug and play" wiring harness from Blaufergnugen worth the $150 they are asking for it or am I better off making my own? I have some euros on their way to me and I am going to need to know what's the best route to go. Isn't there something on Huw Powell's website about a wiring harness schematic?
Travmonster
Augusta GA
Travmonster
Augusta GA
Im with you Evilclown... I never got too in to wiring things up...
The "plug and play" works very nicely... All you need to do is route it so it all fits, place the H1 switch somewhere... (or wire it into the highbeams if you like.) I put mine in the driver's side storage cubby wall... and plug the old headlight plug into the adapter and your good to go.
I had to tweak it a little (cut it) to fit my configuration (h4/h1s on early coupe). + the h1's are wired to my high beam circut. The harness comes so you can wire it up 2 different ways.
Also, there's hook ups for the city lights!!
I do wiring for recording studios for a living (now freelance, that means I'm unemployed!).
Blau's quality is very good and directions are very good. It's probably a 3hr. job to instal it. If you made your own harness and didn't kluge it together, it would take 1 full day minimum!
The difference in brightness is night and day! I instaled 80w/100w H4's and 100w H1 bulbs, with the beams on I can see ****ING sputnik!!!!!!!
Sorry, I have a light fetish, and I sometimes get carried away!!
:-P :-P :-P :-P :-P :-P :-P :-P :-P :-P :-P :-P :-P :-P :-P :-P :-P
<center><img src="http://suvlights.tripod.com/suvlightscom/images/wireharness.jpg"></center><p>Check out the link. This wiring harness is $35 Plus $8 shipping. Very high quality, and they are willing to do custom ones if you ask for no aditional charge. (like 9004 input to H4 output or 9004 input to 9007 ourput, etc)....<ul><li><a href="http://suvlights.tripod.com/suvlightscom/html/wire-harness.htm">The less expensive alternative</a></li></ul>
I've been to a LOT of NAPA's and every one (even the crappy ones) have the 80/100W bulbs for $11 each. They are usually not with the headlight bulbs. They are with the other accessory bulbs. They are in Wagner blister packs. They are labeled something like H4 bulbs for Off-road/motorcycle use only.
