getting a broken bolt out
Hello all, and Merry Christmas!
I was changing the transmission mount on my car today, and unfortunately one of the 2 little side bolts on the mount broke off. Does anyone know what would be the easiest way to get that sucker out? I got the other one out and the big 19mm bolt as well (the mount is now out of the car).
Is there a way I can get away with this without taking off the whole transmission mounting piece (L-shaped metal piece, (p/n 855 339 103 C, page 49-10 of the ETKA) that bolts to the transmission and the subframe/body via the mount).
By the way, the small bolts are 6 mm allen bolts.
Thanks all,
Mladen
Thanks all,
Mladen
Re: Ever think about...
Well, the bolt was not bad to begin with. However, when I tried to twist it off with the allen key (with a pipe on the end of it for leverage), the head snapped off.
Since the bolt was in (very) good condition but so severely seized that the heand snapped off, I think that there isn't much chance of being able to get it out with a screwdriver (the force required wold be too much). I appreciate you throwing the idea in, though.
Thanks,
Mladen
Thanks,
Mladen
In that case, head to Pep Boys for a bolt extractor.
A small hole is drilled into the bolt. Once the hole is drilled, tap the extractor into the hole, then remove. You could also heat the area around the bolt with a small propane torch. Letting the area sit with some Liquid Wrench on it overnight before attempting to extract the bolt would also help. If <u>all that</u> fails, drill out the entire bolt itself, pick out the metal pieces, then re-tap the hole for another bolt.
use an extractor
<center><img src="http://pictureposter.audiworld.com/38899/extractor.jpg"></center><p>
Here's a picture of mine.
It comes with various size tapered reverse thread taps. This particular one is suitable for M8-M10 bolts(#2). Use a conventional drill bit to drill a pilot hole in the center of the bolt. This tool taps itself into the drilled hole as you turn counter-clockwise.
adminisTerTurbo
Audi Original "S" Cars
06-08-2008 11:57 PM
kemperflow
Suspension Tuning Discussion
08-08-2007 08:47 PM
sidespar
13
04-16-2007 10:20 AM
