had the clutch replaced on the 4kq
cost me 2 grand in total. that was with the labor, clutch assembly, new slave cylinder, header pipe and front end bushings. yes, the last 2 had nothing to do with the clutch at all but they needed replacing. it took them 14 hours to change the clutch. i guess i wouldve tried it myself if i had the tools and the time but i have neither so there it is. just thought id throw something out there for you to read when youre bored
i would of threw in new tranny mounts for a price of 2 grand. that is insane, book time is 8 hrs, if you've never done a quattro clutch and you have hand tools it takes me 10 hours without a lift. i'm sure i could cut a few off with one and i usually don't use a transmission jack. this would save an hour as well.
14 hours is just too long, seems you are happy though, that's all that matters.
my clutch job cost me $250 plus a day of my time
and that include all clutch parts and master/slave and transmission mounts.
get a bentley it will save you money.
HTH!
rich
'86 4kq
HTH!
rich
'86 4kq
It took me almost 10 hours to do the clutch and slave cylinder on my car, and that was with a lift. 14 hours isnt unbelievable for all the work that was done considering the problems that you can run into.
the bushings took 4 hours and the header pipe had to be switched as well, not to mention my mechanic is a few weeks out of knee surgery. he wants me to bring it in for a new clutch master cylinder too but i found one for 70 bucks and it looks easy enough, anything i should know before i go changing that?
The clutch master can be a PITA! Check to make sure your firewall where it bolts up at is not cracked!
Bleeding the system can become a real PITA as well. Sometimes they dont like to bleed correctly.
BillyP
17
01-04-2008 12:51 PM
Super-1303
01-26-2003 02:28 PM
