Head Question
I can get a complete WK (early 5kt) head (162xxx kms) for $125...head, cam, distributor, cam cover etc. I know it will fit my WE block, but what is the advantage? Could I expect to see appreciable HP gains? He won't sell the cam separately, that's what I was after initially. Any thoughts?
Dan
Dan
I have the stock one from my 87 4ooo Q and I have a cam from I think a 84 cgt ( I would have to check )are these the wrong ones (hydrolic) or they good ? I put a blau 272 in my car its really nice ...
Positive. As a matter of fact, the head gasket I bought has the following engine codes listed as applicable applications:
WH, WN, 1.5l I5
DY, KE, KG, KH, KJ, KK, KL, GV, WB, WC, WE, WJ, WK, WR and WS, 2.2l I5.
Ironically, I took the time to look some of these engine codes up. There are diesels, normally aspirated and turbo mills that all use the same gasket. Based on that, I am certain that the two heads are compatible with the block. Just to be sure, I compared the 2 on Friday night. They look identical, too my eyes anyway!!
Dan
WH, WN, 1.5l I5
Dan
After experiencing the problem of the past couple days, I'm not certain I want to say for sure there is only 1 WE code style engine (head). Both heads I have are definitely solid lifter units, but I still do not understand why the cams were not standardized between the two. So to answer your question, I require the shorter, solid lifter cam! I'm sorry, I know that is an awfully vague answer. DDG, can you shed some light??
Dan
Dan
Cool. But I would give blau or someone a ring before I made the swap. The hydro lifters means no more adjustments....
Good luck
P.S. I have to pull my head since I have a broken stud and so I picked up a gasket set also.
Same deal, brand is elring and it says DY, KE, ..............WE.
Good luck
83UR-Dont-run
Quattro: Turbo / Ur / Sport
10-19-2003 05:36 AM
GlasSman
01-24-2003 12:21 PM
