Help with sudden stalling...
Old 10-05-2002, 11:10 AM
New Member
smurfy's Avatar
Default Help with sudden stalling...
Alright, this is a strange one... I was driving along in my 4000s 5-cylinder yesterday, and suddenly the car lost all power (including power steering) and just drifted to a stop.... Up till this point, it was running great, and there were no signs whatsoever that anything was wrong.
When I tried re-cranking the ignition, it would crank, but would refuse to catch.... about 30 minutes later, I tried again, and it caught on the first try, but the engine would run for about 30 seconds, and then it would stall again.... This occurred late in the day, after a few hours of driving, so obviously the engine was well warmed up. There was plenty of gas in the tank as well.
In the end, I had the car towed...
Am not knowledgeable enough about electrical systems to know what the problem is, though I suspect its either the alternator or the solenoid... or battery?
Any help would be much appreciated. Thanks!
Old 10-05-2002, 11:16 AM
furiousgeorge's Avatar
Default Re: Help with sudden stalling...
plugged up fuel line? when was the last time your fuel filter was changed?
Old 10-05-2002, 11:54 AM
Cdn Blue Coupe's Avatar
fuel filter?
Old 10-05-2002, 12:04 PM
Member
Dwight V.'s Avatar
You need to determine if it's fuel or spark.
Check to see if the plugs are sparking. If they are, you need to figure out if it's getting fuel. Then diagnose backwards from there.
It's not the alt, batt or solenoid. You're right, you don't know much about electrics.
Such a sudden failure is most likely electrical. I'd check fuel pump and relay as a probable culprit.
Old 10-05-2002, 03:38 PM
CGTBrad's Avatar
Sounds fuel related to me...
Old 10-06-2002, 08:24 AM
New Member
1hot4000s's Avatar
Default k this happend to me like a week ago....
check your 02 sensor! mine was putting in 5 times the fuel it needed and it was flooding the car out so it would die!!! hope this helps seeya!
Old 10-25-2002, 10:24 AM
New Member
cycle_rcr's Avatar
Default Re: Sounds fuel related to me...
Pull out the fuel pump relay. Carefully pry off the cover. Look at the solder joints for cracks. Look especially carefully at the big copper conductors. If cracked, relsolder. If not competent at soldering, find someone who is
Allan
daveno1
07-16-2010 02:27 PM
zaliah898
01-25-2009 10:40 PM
cgtdenmark
06-20-2007 11:01 PM
foberg34
11-22-2003 05:27 PM
pawwpaw
10-07-2002 12:17 PM
Quick Reply: Help with sudden stalling...
